Budget (including currency): trying to keep it under $3000 USD excluding thing I have already purchased
Country: USA
Games, programs or workloads that it will be used for: 3d rendering, photoshop, Cod, valorant, Forza, star citizen, Minecraft, video editing
I Already purchased the power supply and the gpu as a bundle with a few other things from antonline
I also wasn't really sure about what to go with for the m.2 im looking for a good 2tb one
CPU: intel core i9 11900k
Motherboard: EK-Quantum MSI MPG Z590 CARBON EK X D-RGB
Ram: Corsair Vengeance RGB Pro 64 GB (4 x 16 GB) DDR4-3600 CL18 Memory
Storage: Samsung 980 Pro 2 TB M.2-2280 NVME Solid State Drive
GPU: (already purchased) EVGA 3080 ti 12 GB FTW3 Ultra Gaming
Case: Lian Li O11 Dynamic
Power supply: (already purchased) EVGA G3 750 W 80+ Gold Certified Fully Modular ATX
Water Cooling: https://www.ekwb.com/custom-loop-configurator/shared/oW60e4c1cc56fc3
https://linustechtips.com/topic/1354184-first-build/
I would recommend a Ryzen 9 5800x/5900x instead of the i9 but other than that that is a good looking build.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1354184-first-build/#findComment-14855145
Country: USA
11900k is an 8 core and you can get the same performance with an 11700k
Or not just get a 10 core 10850k instead
Corsair Rgb pro is a ripoff as non rgb ram equivalents are usually around 100$ cheaper aand rgb equivalents around 40-60$ even worse its cl18 not cl 16
like most 3200 and 3600mhz ram, look at trident z rgb as an alternative
That psu is eh but i guess itll work, better to buy a revolution df or msi mpg 850w
Btw are you even gonna overclock?
Cause i already consider buying an expensive cooler stupid if you arent gonna overclock, if you arent gonna oc with a custom loop then thats a whole other level of stupid as you already have lower temps, only reason to not overclock is power bills but then youve spent this much on the bloody custom loop xD
Oh you should have gone ryzen btw, 8 core isnt gonna be enough for your photoshop nor 3d renderong and video editing, 10 core is just barely cutting it, get a 12 core instead like the 5900x
https://linustechtips.com/topic/1354184-first-build/#findComment-14855150
Yea this looks more like a copy of the usual expensive watercooler rainbow puke disco ball rgb pc youd find on youtube
They look pretty but the part selection is usually rubbish, overpriced asthetics, underpowered cpu, etc
Atleast here the only rubbish parts selection is the cpu and ram, and psu is eh but itll work, there are better value builds out there but considering you have this budget and have gone intel (which is cheaper than ryzen) then i think its fine for this budget, just for the love of god swap the psu and ram xD
Btw if you go 10 core i9 then you cant use the full potential of a 980 procause no pcie gen 4 on 10th gen intel, so go with a 970 evo instead
https://linustechtips.com/topic/1354184-first-build/#findComment-14855155
yes, I definitely am planning on overclocking, if I wasn't I would have just tossed an aio on it.
The psu was included in the bundle that I was able to get the 3080 ti in so im hoping that I can use it.
The cpu does seem to be a bit of an oversight on my part. Hows a 5900x and a Asus ROG Crosshair VIII Formula sound? Also when I configure that in pcpartpicker it says that the Motherboard might need a bios update to work with that cpu.
By going with more cores is there going to be much of a sacrifice in Gaming performance?
https://linustechtips.com/topic/1354184-first-build/#findComment-14855518
That depends, though you can just set a static all core overclock of 4.8ghz at 1.3v and itll prob work fine
The max safe volt for dailying a 7nm ryzen is around 1.4-1.45v
https://linustechtips.com/topic/1354184-first-build/#findComment-14855531
ok great
Do you think I am going to run into the issue of that board needing a bios update to work with that cpu?
https://linustechtips.com/topic/1354184-first-build/#findComment-14855701
1 minute ago, Vince Smith said:
ok great
Nope, its been like a year since these b550 boards were launched so very low chance you have to bios update
https://linustechtips.com/topic/1354184-first-build/#findComment-14855709
