Ok so I'm looking to build a pc. With the pc I want to play Minecraft and Rocket League along with recording and occasionally stream. My budget is $1600 USD. Here is a list of parts I currently want. If anyone wants to make some changes to the system please feel free to do so. I do have some things I'd like for the pc to have so here's what I would like for it. 32GB DDR4, onboard Wi-Fi on MoBo,  an NVIDIA chipset GPU, at least one 2TB HDD, an AIO, and a fully modular PSU.
Current list: https://pcpartpicker.com/list/MHKwsX
CPU: Intel Core i7-10700K
MoBo: MSI MPS Z490 Gaming Edge
RAM: G.Skill Ripjaws V Series 32GB (Dual Channel)
GPU: EVGA NVIDIA GeForce RTX 3060 12GB XC
M.2 SSD: Samsung 980 500GB
PSU: MSI 650W 80+ Gold Fully Modular
Case: NZXT H510i
AIO: Cooler Master MASTERLIQUID ML240L RGB V2
https://linustechtips.com/topic/1353924-i-need-help-with-pc/
Case: NZXT H510i
If you arent overclocking dont bother with an expensive board tho a k cpu is good for undervolting aswell, if you arent gonna oc or undervolt get non k cpus instead
https://linustechtips.com/topic/1353924-i-need-help-with-pc/#findComment-14853297
https://pcpartpicker.com/list/KGhhHz
Another list that stretches your budget to its limit
10850k cause more cores is better for streaming
Cooler is eh cause budget, just undervolt the 10850k to 1.2v at 4.8ghz in the bios
Z590 board cause its cheap
You can add a hdd later
Gpu is up to you
You may want to consider getting a 10900f instead though you may need abit more voltage to reach 4.8ghz or just lower your freq to 4.6 and acheive the same undervolt
https://linustechtips.com/topic/1353924-i-need-help-with-pc/#findComment-14853316
Just now, AvocadoDude1 said:
Should I use the NZXT X53 AIO instead?
Aios are uneccesary unless you are running out of space near the socket
And by the time you are running out of space near the socket youd need a 360mm aio to even keep up with an air cooler of the same performance
https://linustechtips.com/topic/1353924-i-need-help-with-pc/#findComment-14853336
