SSD TIER LIST - Storage Devices - Linus Tech Tips
This SSD tier list should help you decide on a suitable option in your budget that is available where you live.
Burn a flash drive with a windows ISO before installing the new SSD. You can download Microsoft's utility here:  Download Windows 10 (microsoft.com)
https://linustechtips.com/topic/1353673-need-help-with-ssd/#findComment-14851261
thanks bud.
what about the old OS ?
https://linustechtips.com/topic/1353673-need-help-with-ssd/#findComment-14851266
You will need to wipe the hard disk after it's removed. Alternatively you can boot into the windows installer on your flash drive and format your current drive there.
so hear me out and tell me if I'm wrong.
GET the SSD connect it with MOBO and PSU.
Create WIN 10 bootable on a flash drive
Boot into the Flash drive
Format C on hard Disk
Install OS on SSD
https://linustechtips.com/topic/1353673-need-help-with-ssd/#findComment-14851273
Install OS on SSD
1. Download the installer, burn the iso onto a flash drive
2. Boot into the installer, wipe your old hard disk (provided you backed up or don't have any important data there)
3. Shut down, install new SSD.
4. Boot into the installer again and install windows on the new SSD.
https://linustechtips.com/topic/1353673-need-help-with-ssd/#findComment-14851278
Thanks man appreciate
https://linustechtips.com/topic/1353673-need-help-with-ssd/#findComment-14851280
