Lian Li O11 AIR Fan Placement Help?
By
RonanStuds
in Cooling
in Cooling
Solved by NorKris,
2 minutes ago, RonanStuds said:Okay so where everything is is fine? I can see it working well but I do agree that the fans are pushing hot air into the radiator. How can I eliminate this problem? I could push the right three intakes instead for the radiator and the radiators original location for exhausts
Yellow as radiator, and fans the same way ur thinking. thats the best
4
16
JustAPcGal ·
Posted in Graphics Cards7 -
Pinto1 ·
Posted in Power Supplies1 -
1
6
TJSABU ·
Posted in CPUs, Motherboards, and Memory2 -
3
4
play_circle_filled
Latest From Linus Tech Tips:
Why I’ll be Taking VPN Sponsorships Again… and Why I Stopped
