Budget (including currency): 1.5k usd
Country: U.S.A
Games, programs or workloads that it will be used for: Minecraft and hopefully some high graphic games also video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://pcpartpicker.com/user/Corrigan2008/saved/QYV9cf this is what I am looking at and I was wondering if anyone has any ideas on how to make this cheaper with he same performance or possibly even better thanks in advance
https://linustechtips.com/topic/1353472-my-first-pc-build/
Country: U.S.A
You can use the stock cooler and get a cheaper Z490
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849724
Stock cooler on a 10700K? (Not only would that be a thermal nightmare, 10700K doesn't include a box cooler)
I would actually recommend a slightly better aftermarket cooler to allow the 10700K enough thermal headroom to boost all the way up.
Other than that, SSD can be saved on by picking a slightly cheaper one that you realistically won't notice the difference between (unless SSD performance is super important to you)
you don't need to buy thermal paste because coolers come with paste pre-applied.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849729
ok thanks could u help me find some of these parts I am in a big rush
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849737
I would recommend this: https://pcpartpicker.com/list/k9xJrr
it has the improvements mentioned (better air cooler, cheaper motherboard, cheaper storage) which lowers the price.
You can decide to just save money and get this, or upgrade storage to 2TB, upgrade GPU, etc.
I didn't touch the GPU because finding it will be a struggle on its own, good luck.
Laptop:
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849745
Thank you so much
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849748
Btw op are you gonna do any overclocking?
Cause getting a k cpu is very stupid if you dont overclock
Though if you get a k cpu for undervolting then thats not a bad choice cause k cpus usually have better silicon than non k cpus aka better undervolting
It is incredibly stupid to buy a k cpu and both not overclock or undervolt it
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849752
ok what do you recommend
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849754
Thank you so much
Just noticed you want a board with wifi. in that case go with this: https://pcpartpicker.com/product/PLytt6/asus-prime-z590-p-wifi-atx-lga1200-motherboard-prime-z590-p-wifi
Laptop:
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849755
K-series CPUs are often better overall CPUs even if you wont overclock. Repeating your personal opinion wont make it the best alternative for everyone.
But, I am also wondering if OP is going to OC. There is no big advantage I can think of going with Z490 instead for like H470, other than IO or general better components. The CPU cooler choice was the part that made me wonder if it was going to be overclocked.
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849762
Still dumb getting a k cpu, esp for the ones where the non k variant has a similar boost clock
11400 has a boost clock of 4.4ghz but 11600k has a boost clock of 4.9ghz so its a decent uplift even if you dont oc
But 11700 has a boost of 4.9ghz
And 11700k has a boost of 5ghz, no real improvement here unless you undervolt or overclock
Any other reason to get the k cpu when you dont oc or undervolt and the non k variant has a very similar boost clock to the k variant?
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14849775
Which still doesn't mean that getting the K variant for that little extra performance is just straight up a bad idea. For some people, it's worth it.
For example, I think it was Rileys Intel Extreme Tech Upgrade here, where he chose a overclockable CPU (by Intel of course because sponsors and stuff) and a non-overclocking capable mobo.
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14853422
I stand my ground its stupid to get a k cpu if you arent gonna undervolt or oc it especially when the boost clock of the non k variant is similar xD
Though if the price difference is very little like 5-10$ then i guess its less stupid but still stupid nontheless esp if you dont oc or undervolt it
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14853436
I agree, it is stupid, but it isn't totally insane since considoring most people don't overclock anyways (not in this community).
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14853446
Well before this completely hijacks this topic ill just end it at
K cpus are stupid to buy if you arent ocing or undervolting but if they provide higher (not slightly) boost clocks than their non k counterparts and at the time of buying are very similar to the non k variant then its not that stupid
Dont continue this argument of sorts cause we dont wanna hijack this topic do we xD
https://linustechtips.com/topic/1353472-my-first-pc-build/#findComment-14853505
