Budget (including currency): $1500 USD
Country: New York
Games, programs or workloads that it will be used for: Warzone, Fall guys and other resource hungry games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Just the monitor was bought so far.
Cheese
https://linustechtips.com/topic/1353456-need-help-for-a-friend/
Country: New York
will he overclock?
does he want a full setup?
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849590
2 minutes ago, Amer said:
I mean I did mention that only the monitor was bought...
Yeah, but... is he considering to buy speakers, desk, headset, mic, keyboard, mouse etc. is that budget or not?
Edit:
If he is not considering any of the above then:
PCPartPicker Part List: https://pcpartpicker.com/list/TQGJrr
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($396.04 @ Amazon)
CPU Cooler: Noctua NH-D15S chromax.black 82.51 CFM CPU Cooler  ($99.95 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($141.22 @ Amazon)
Memory: G.Skill Trident Z Neo 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($109.99 @ Newegg)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($55.49 @ Amazon)
Video Card: NVIDIA GeForce RTX 3060 Ti 8 GB Founders Edition Video Card  ($400.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($134.99 @ Corsair)
Total: $1532.66
Generated by PCPartPicker
PRICES ARE IN USD
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849605
https://pcpartpicker.com/list/Dgg7LP
Another mediocre pcpartpicker list by me .-.
Gone intel cause for whatever reason 10700f is cheaper than a 5600x
A rather basic z490 board but good enough vrms for this 8 core and if you get a really good deal on the gpu and have some budget to spend consider getting a 10850k which is really close in price to a 5800x tho upgrade the cooler aswell unless you would like to undervolt
Gpu is up to you
Asthetics yeeted as usual, if you have some budget leftover then go ahead and spend on asthetics
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849615
PCPartPicker Part List: https://pcpartpicker.com/list/mJLRW3
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($394.00 @ Newegg)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: MSI MPG B550 GAMING PLUS ATX AM4 Motherboard  ($144.99 @ Amazon)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($71.97 @ Amazon)
Storage: Sabrent Rocket Q 1 TB M.2-2280 NVME Solid State Drive  ($109.98 @ Amazon)
Video Card: NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card  ($500.00)
Case: Metallic Gear Neo Air ATX ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Antec NeoECO Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($84.99 @ Newegg)
Total: $1415.91
Generated by PCPartPicker 2021-07-04 09:58 EDT-0400
left a 85 usd for mouse and keyboard. i didn't put any periphrals because they are subjective. but if i have to the km360 is a great keyboard for 50 usd only. and you could get a g502 hero mouse ( 38 usd ) or if you want a lighter mouse the corsair harpoon rgb pro ( 25 usd )
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849627
CPU: Intel Core i5-10600 3.3 GHz 6-Core Processor  ($226.98 @ Amazon)
Motherboard: MSI MAG B460 TORPEDO ATX LGA1200 Motherboard  ($109.99 @ B&H)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($61.99 @ Amazon)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  ($75.08 @ Amazon)
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($105.00 @ Newegg Sellers)
Keyboard: Redragon K551-RGB Wired Gaming Keyboard With Optical Mouse  ($57.99 @ Amazon)
Total: $764.49
Generated by PCPartPicker 2021-07-04 10:31 EDT-0400
Use the iGPU for now and wait for stock on an rx 6800xt or rtx 3080.
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849659
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.00 @ B&H)
Memory: Patriot Viper RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($72.81 @ Amazon)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($112.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 3070 Ti 8 GB GAMING OC Video Card  ($600.00)
Power Supply: Antec Earthwatts Gold Pro 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($62.79 @ Amazon)
Keyboard: Tecware Phantom RGB Wired Gaming Keyboard  ($45.99 @ Amazon)
Mouse: Logitech G502 HERO Wired Optical Mouse  ($37.99 @ Amazon)
Total: $1426.55
Generated by PCPartPicker 2021-07-04 10:55 EDT-0400
geometry is hard
b550 > x570
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849688
12 minutes ago, Downkey said:
On almost every parts list you post here on the forum; has 3200 Mhz RAM speeds, while Ryzen really benefits from faster timings and faster speed i.e. 3600 Mhz.
And the interesting thing is, they still got budget left. and by investing 10 or 15 bucks more you can get 3600 Mhz RAM...
So, may i ask, why do you do this?
Is there any logic behind this or what...????
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849720
Contrary to popular belief, 3600 CL16 barley makes any difference at all over 3200 CL16. The most I’ve seen is around a 4% performance benefit in some AAA games. Unless OP has a massive budget, 3200 CL16 is the move IMO.
In my list, I put a 3070ti and the price was $1426. If OP wanted to expand the budget just a little and get a 3080, they could. With 3600 CL16, they would have to spend around an extra $21 more. That makes $1447, which if they wanted to add a 3080, it makes it much more over budget.
TLDR - Not much more performance, saves money
geometry is hard
b550 > x570
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849948
Edit:
Total: $1532.66
PRICES ARE IN USD
Also, a 3060ti for $1500 is pretty mediocre imo. Since OP is gaming, a 5600x + 3070/3070ti would be a better combo. Also, that PSU is a bit overpriced and really unnecessary. If you really wanted a decent 850W, the Enermax D.F Revo is around $16 cheaper and is also a really good PSU.
Also that SSD is really overpriced. $100? That could get you a 1TB NVME drive.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1353456-need-help-for-a-friend/#findComment-14849953
