Hi Guys
I've got an 8gb dual channel kit of corsair vengeance ram marked 1600mhz.
Looking at the BIOS, the RAM speed has automatically set to 1333mhz.
Am I going to do myself or my system any diservice by overiding the BIOS and setting the RAM speed to 1600mhz?
Luc
Corsair Obsidian 750D | Intel i5-4560k @ 4.4Ghz | Corsair H100i with Stock Fans | Gigabyte R9 280 3GB OC
Gigabyte Z87X-UD3H | 2x 4GB Corsair Vengeance 1600Mhz | Corsair RM850 80+ Gold | Samsung 840 EVO 120GB SSD | 500GB Seagate Barracuda
https://linustechtips.com/topic/135243-ram-speed/
There should be a way to set the XMP profile to 1600mhz
CPU: i7 3770k @4.5Ghz 1.26v Cooler: H100i 2 Sp120 Quiets MoBo: MSI Z77 MPOWER Big Bang RAM: 16GB G.Skill Sniper 2133Mhz CL9 Graphics Card: Asus Direct CU II R9 290 Storage: Vertex 4 128GB, WD Black 1TB Case: NZXT H440 Green
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799087
all kits do that and your expected to boost it to 1600 mhz. why? i dont know. is it safe? entirely.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799109
One of lifes little enigmas.
Ty for answers guys
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799131
So, i went into BIOS, and set the RAM to 1600mhz.
This then changed the CAS values from 9-9-9-24 to 9-11-11-29
I have manually set the values back to 9-9-9-24
Does this seem correct?
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799293
what did the manufacturer specify for the kit?
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799317
Corsair specify 9-9-9-24
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799372
then ya youre all set
https://linustechtips.com/topic/135243-ram-speed/#findComment-1799394
