Dualsense Wired Problem (and bsod)
Solved by Ty2525,
The DS4 issue is because the controller has a 3.5mm combo port and windows will try to enable it as default Headphone/microphone device. As for why it is freaking out, idk. Try to disable the current devices (microphone array) disable any Headphones/microphone devices before plugging in the controller. Ensuring everything is disabled will hopefully prevent windows from trying to fight with any devices that want to be the active one. Once you plug the controller in, and it defaults as active device, as long as it doesn't freak out, disable it then enable your preferred devices. If this works, great! if not, try using x360CE instead of DS4 as they are drivers and ds4 might be conflicting with something. Good luck!
