Budget (including currency): 1500€
Country: Denmark
Games, programs or workloads that it will be used for: Inventor and different AAA games
Other details: I will be moving over my RX 580 and SSDs to the new build
CPU: 5900X
CPU cooler: BeQuiet Dark Rock TF
PSU: Corsair SFX SF750
Ram: G.Skill TidentZ Neo 32gb 4000MHz CL18
Motherboard: GIGABYTE B550I AORUS PRO AX
Case: Lian Li TU150
I am not really sure about the motherboard, I can also get a Gigabyte X570i Aorus pro wifi or a Strix b550-i/X570-i. I am planning on getting a 3070 or 3080 next year.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/1352267-itx-build-check/
I've only built ITX for the past few generations.
I'm currently using the Asus Strix B550-i and am really quite happy with it. Then again, when I was in the market they all looked great as there really wasn't that many B550 ITX boards of this caliber.
Really it just comes down to the featureset then maybe software. Some have an USB-Type C header and some don't, etc...
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840890
Country: Denmark
CPU: 5900X
Case: Lian Li TU150
Looks solid but down the RAM to 3200mhz cl16 or 3600mhz cl16 , For the MB b550 aorus or strix will be enough no need for x570
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840901
any reason to get CL16 3600 over CL18 4000? It costs the same for me
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840902
I took a look at a TU150X picture...
Are you sure, the BeQuiet Dark Rock TF fits with the rear exhaus fan?
ITX mainboards are 170x170mm.
BeQuiet Dark Rock TFs width is 163 mm.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840916
Honestly I just went for the biggest cooler with the best ram clerance, since it is a small pc and a relatively warm CPU
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840933
2 minutes ago, Omar.B said:
Its noticeably faster with Ryzen
Ah okay, I will find a 3600 CL16 kit then, thanks
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840934
Here is a picture of a TU150X with a Dark Rock Pro 4. It fits with almost no gap to the rear exhaust fan.
Dark Rock Pro 4's width is is 146 mm.
BeQuiet Dark Rock TF is 140x163x131mm so it can fit or cant, depending on the orientation, I think.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840944
8 minutes ago, suedseefrucht said:
Here is a picture of a TU150X with a Dark Rock Pro 4. It fits with almost no gap to the rear exhaus fan.
Seems like I will be going with the Dark rock pro 4 then, thanks
https://linustechtips.com/topic/1352267-itx-build-check/#findComment-14840972
