Budget (including currency):
Country: Malaysia
Games, programs or workloads that it will be used for:  Gaming
Other details
intel I7 6700k,
crosair 32gb Ram (2133 MHZ)
Gigabyte Z170x Gaming 7
dell 3220dgf (main monitor)
MSI 970 armor
PSU : corsair 1000w platinum
forgot the CPU cooler model but it is crosair AIO
Hard drive : Samsung SSD 850 Evo 500 gb (boot drive C:)
                    Adata SX8200PNP (main gaming drive. as my motherboard do not have nvme slot, so i use nvme pcie adapter)
                   the remaining is SATA storage which is from many years back as storage for rubbish
Hi
my system is quite old especially my GPU as it no longer able to handle new game
i planning to upgrade my GPU
i not able to decide whether going for Nvidia or AMD
as i never use AMD GPU before
the Nvidia DLSS 2.0 is very attractive but my monitor only support freesync
can anyone recommend whether i go for Nvidia or AMD
if go for nvidia i wish to get 3070ti or 3080 as i wanted to last for very long time
if go for AMD which model should i get that almost as powerful as 3070ti or 3080
furthermore, should i upgrade the rest or they should be still useable and won't bottleneck my new GPU
NOTE: can't provide budge yet as the GPU price seems to be dropping , not looking for god tier system. just want a system that able to handle ultra 1440p setting as my current system only provide me 30-50fps for resident evil 8 with extreme low setting
https://linustechtips.com/topic/1352259-need-recommendation-for-gpu/
Asumming normal market scenario you'd be getting somewhere around xx70 series or similar equivalent from amd
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
I have a i7 6700k and the best balance was a GTX 1080(RTX 2060S).  With a GTX 1080 ti(= RTX 2080) it left too much GPU performance not used so I replaced it with an i7 8700k.
When I upgraded to a RTX 2080 ti(= 3070 ti) even the i7 8700k struggled at stock so all my CPUs after it are either 5ghz intels like my i9 9900k or Ryzen 5000 series like my 5800x.
So when you get a 3070 ti or 3080 it will be your CPU holding you back a lot.
What I would do is get a RTX 3060/3070 for your currant computer and save/plan to build a modern 8 core plus computer to use a high end graphics card.
If you plan to build a 10/11th gen Intel or Ryzen 5000 soon just get the 3070 ti/3080 as soon as you can get one at MSRP.
I have got a 3080 and a 3080 ti this month at MSRP so it is becoming doable.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
Oh my
i totally forgot about bottleneck
sadly it mean i need to upgrade alot of stuff
CPU AMD Ryzen 5900x seems the best choice compare to intel i9(alot of bad feedback)
so here are what i might upgrade to, can anyone comment if is good combination or any changes made
the main purpose is not causing bottleneck
CPU Ryzen 5900x
Motherboard : gigabyte: B550 AORUS PRO
RAM: x2  KINGSTON HyperX® Predator RGB 16GB 3200mhz, or should i go for x4?
HardDrive: might add 1 new Nvme ssd or use back old hard drive
PSU: currently already using crosair 1000w platinum , should be still usable
GPU: 3070ti or 3080
done some digging and manage to find benchmark result
https://www.gpucheck.com/gpu/nvidia-geforce-rtx-3080/intel-core-i7-6700k-4-00ghz/
looks like i7 6700k did get bottleneck but at 1440p it did not get huge bottleneck
the game i play like battlefield 5 able to reach over 170fps with ultra setting
with this result i can slowly upgrade my rig , starting with 3080 first
originally thought it will get huge bottleneck
