SFF-8643 Cable for Storage
Solved by NelizMastr,
iirc U.2 is not compatible with SATA and SAS so it won't work. You'll need an add-in card with SATA ports or SAS if you need more SATA ports.
bluesheep ·
Posted in Graphics Cards2 -
Never touched these amd adrenaline software settings before, are they worth turning on for fps gain?
Theminecraftaddict555 ·
Posted in Graphics Cards0 -
2
Username726 ·
Posted in Audio0 -
ARandomPerson ·
Posted in Hot Deals0 -
Blufire ·
2
1
2
4
play_circle_filled
Latest From Linus Tech Tips:
I Want A Job At The Roblox Store - WAN Show June 7, 2024
