I have a budget of $2700 Aud but want to save a bit more money if possible. I want this pc to be able to be able to perform high end gaming with a high enough fps so it does not effect gameplay. I also want it to be able to stream games.
PCPartPicker Part List: https://au.pcpartpicker.com/list/GrcGCz
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($420.00 @ Amazon Australia)
CPU Cooler: Corsair iCUE H100i ELITE CAPELLIX 75 CFM Liquid CPU Cooler  ($229.00 @ JW Computers)
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard  ($179.00 @ BPC Technology)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-2666 CL16 Memory  ($149.00 @ Centre Com)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($139.00 @ Centre Com)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ BPC Technology)
Video Card: MSI Radeon RX 6800 16 GB Video Card  ($1169.00)
Case: Cooler Master MasterBox TD500 Mesh White w/ Controller ATX Mid Tower Case  ($129.00 @ PC Byte)
Power Supply: Corsair RMx White (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.00)
Total: $2641.00
https://linustechtips.com/topic/1352106-pc-advice-and-planning/
Total: $2641.00
I wouldn't go for that ram, it's only 2666 mhz CL16. Go for something that is 3200 mhz CL16 or higher
https://linustechtips.com/topic/1352106-pc-advice-and-planning/#findComment-14839785
Total: $2641.00
Also, You could definately save a lot if you can get a gpu at msrp, but if not, then that gpu is a good choice
https://linustechtips.com/topic/1352106-pc-advice-and-planning/#findComment-14839788
