6 minutes ago, TheeCanadian08 said:
hey i recently picked up the modi and magni stack.
im currently using the dt990 250ohm how do i set it up properly on windows
On the connection to the PC side, you plug it in via USB, that's in. No driver install necessary, it just uses the a built in Windows audio driver.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
hey thanks do i need to change format quality or just leave it at default
Leave it to default. Maybe 24 bit 48khz. Or 44khz
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
10 minutes ago, TheeCanadian08 said:
Great thanks and I’m assuming I only need just the modi plugged into the wall and that the magni can be bus powered right
Opposite. The Modi gets power over USB however the Magni is an amplifier. Of the two it's the one that comes with a big heavy power brick and needs to be plugged into the wall.
Okay thanks and bus powered is enough for that it wouldn’t make a difference if I plug it into the wall and then to pc via optical ?
That could work too, yeah. It just needs a basic 5v USB power so even an old phone charger will work.
