Recommendation for G-sync monitor
Solved by Stahlmann,
First off. With your budget you should forget about a native G-Sync monitor. Any good FreeSync monitor with certified "G-Sync compatibility" will result in the same user experience.
For your budget i'd go for one good monitor over 2 mediocre ones.
The LG 27GP850 will be a good fit. It's a really well reviewed 27" 1440p 180Hz IPS display.
Featured Topics
NerdzYanez ·
Posted in Troubleshooting0 -
genshin ·
Posted in General Discussion16 -
AndreiArgeanu ·
Posted in PC Gaming3 -
4
1
DOODLEROCKS9 ·
1
4
qwerty167 ·
Posted in Graphics Cards3
play_circle_filled
Latest From ShortCircuit:
We've Never Unboxed a 3D Printer Like THIS before! - Micronics SLS 3D Printer
