Currently have 1x 8gb 2933mhz ram (not sure if its dual rank) installed in an asus rog laptop, intel i5-10300H, 1650ti, and Warzone crashes within minutes of opening. The problem appears to be that my memory completely fills up. Would I make my situation better, or would I shoot myself in the foot by adding 2 sticks of 4gb 1600mhz dual rank ram in addition to the 8gb stick mentioned previously?
https://linustechtips.com/topic/1351129-memory-issues-plaguing-a-massive-n00b/
I advice you to get the exact same ram stick as the already installed 8Gb one, and install another one of that. Technically speaking i dont think you would even be able to install the other 2 sticks, since 1) most laptops only have 2 lots 2) 1600mhz is the older, ddr3 version speed, which has different socket for it than ddr4.
