Budget (including currency): Around 1000 CAD after tax (and also before gpu.)
Country: Canada
Games, programs or workloads that it will be used for: Minecraft, Fortnite, Csgo, R6S, OBS, very light streaming and editing.)
$240 CPU : i5 9600k (I will use the iGPU until gpu prices drop in my area.)
$80 CPU Cooler : Noctua NH-U12S (I was thinking about this because I don't want to go watercooling and also don't want a low quality air cooler.)
Waiting for the 3060 to go down in price but currently it's about 560 in my area. If I get needy I'm going to go with the 1660 TI for convinience because it's about 390 currently.
$110 RAM : G.SKILL Ripjaws V Series 16GB CL16 (2x8GB) DDR4 3200MHz (If you guys know of any Ram that I could use for this price then I'm good with changing.)
$125 Storage : SN550 1TB NVME (I will also get a 2TB HDD for about $60 down the road.)
$150 Motherboard : Gigabyte Z390 UD (If you know of any other motherboards that are decent and will support a future upgrade to the 9900k then I'm up for it.)
$90 PSU : Phanteks AMP 550W 80+ Gold (I would like something at least semi or fully modular but I'm willing to sacrifice here.)
$70 Case : Fractal Design Focus G Black (Just a cheap case that's good for the price. Any other suggestions are ones that I would be open to.)
I'm wondering not only if this would satisfy what I'm looking to build it for but ways that I could tone down the budget and still get a similar performance. I've done a lot of research immersing myself into this new world over the past 18 months and honestly should have asked my parents for a loan or something before the gpus got way out of hand. Now I'm trying to lower the budget and keep around the same performance. I already have a VG24VQ monitor that I use with my current laptop and a Razer Blackwidow Elite paired with a Glorious model O for the keyboard and mouse (I got both used for a fairly cheap price compared to new.) The pc is the final step and I don't want to make any wrong purchases. Thank you in advance!
https://linustechtips.com/topic/1350725-build-plan-and-costing/
I would recommend swapping this out for a Ryzen 7 3700X, it is $40 more for 2 more cores and 4 additional threads  -->     https://pcpartpicker.com/product/QKJtt6/amd-ryzen-7-3700x-36-ghz-8-core-processor-100-100000071box
Cheaper RAM with a good heat spreader -->     https://pcpartpicker.com/product/zBTzK8/silicon-power-xpower-turbine-16-gb-2-x-8-gb-ddr4-3200-memory-sp016gxlzu320bda
Most users aren't even going to notice a difference going from a SATA SSD to an NVMe one, on larger drive capacity options such as 1TB especially, the NVMe version can be significantly more costly. -->     https://pcpartpicker.com/product/ffbwrH/sandisk-ssd-plus-1-tb-25-solid-state-drive-sdssda-1t00-g26
The Intel Core i9 9900K already exists (https://www.amazon.com/Intel-i9-9900K-Desktop-Processor-Unlocked/dp/B005404P9I). The AMD AM4 platform will give you a lot more flexibility for future processor upgrades and is required if you're going for a Ryzen processor --> https://pcpartpicker.com/product/4mjNnQ/asrock-b550-phantom-gaming-4-atx-am4-motherboard-b550-phantom-gaming-4
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1350725-build-plan-and-costing/#findComment-14829437
As for the cpu I use CAD and the main website that I'm going to be using will be https://www.canadacomputers.com/ because there is a store by me.
Thank you for the ram idea though
Although the difference is not noticable to most people the price difference and performance for my area is much better. A 1TB SSD costs about 120 CAD when not on sale and the SN550 costs 135 when not on sale. Thank you for the suggestion though.
I am aware that the 9900k already exists but it is the highest quality that I would ever need in 2-3 years which is when I would upgrade to it. But again, thank you for the suggestion.
I would also like to clarify this specifically. Intel CPU's for some reason are selling at a lower price when compared to AMD for the same performance in my area and this lead me to go to Intel rather than AMD. I would also like to put this out there... I like AMD's Ryzen series but for the price that I need to spend on it I just don't have the budget for the same performance.
https://linustechtips.com/topic/1350725-build-plan-and-costing/#findComment-14829479
