Budget (including currency): Looking to spend around $1600 USD
Country: US
Games, programs or workloads that it will be used for: Gaming, Autodesk Designing,
Hi, Looking for help on some parts of my build and overall recommendations
- Cooling situation with Addressable RGB. I don't know the best AIO coolers that are compatible with case fans RGB wise. I bought the Corsair RGB Hub but it doesn't seem to work with the CPU Cooler I have.
- Along with the hardware itself, I'm not sure the best way to do all the Push/Pull fans for the best overall system and how to do my CPU cooler fan graph.
- Best value GPU with my build (I can wait until the prices are better). I'm not sure what's the best GPU I should go for that's within my budget range and maximizes the most out of my build.
Current Build
CPU - AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (Bought)
CPU Cooler - Cooler Master MASTERLIQUID ML120L RGB V2 (Looking to replace)
Motherboard - Asus ROG STRIX B550-I GAMING Mini ITX AM4 Motherboard (Bought)
Memory - G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (Bought)
Storage - Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive (Bought)
              - Samsung 860 Evo 250 GB 2.5" Solid State Drive (From old PC)
GPU - EVGA GeForce GTX 960 2 GB SSC ACX 2.0+ Video Card (From old PC)
Case - Thermaltake The Tower 100 Mini ITX Tower Case (Bought)
PSU - Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (Bought)
Extra Case Fans - Noctua A14 PWM chromax.black.swap 82.52 CFM 140 mm Fan (Coming In)
                             - Corsair ML140 Pro RGB 55.4 CFM 140mm Fan (Looking to replace)
Any help would be appreciated!
https://linustechtips.com/topic/1350024-need-help-on-pc-build/
