"Radeon rm5 3335" isn't even a real product so I don't know how much help you expect us to give you based on this description of the problem.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1349454-low-fps/#findComment-14819162
Low fps (assuming that's what "fos" was supposed to be) is exactly what I'd expect from it.
https://linustechtips.com/topic/1349454-low-fps/#findComment-14819167
It's a low-end laptop GPU using DDR3 from 2015.
https://linustechtips.com/topic/1349454-low-fps/#findComment-14819250
