Hello today I started experiencing artifacting on my pc.
specs:
amd 5950x
asus rog strix 2060 super
32gb gskill
asus b550-f wifi
ive tried a new psu 850+gold
swapped in an old 2070
changed pcie slots for graphics card
reseated cpu
tried old ram
Ddu for fresh drivers
temps seem stable
no power spikes
was able to screen cap so it’s not the monitors
running prime95 to try to test cpu under stress. no crashing after 30 minutes and no artifacting with videos playing.
morning edit: ran prime95 over night, no crashes.
only really happens when I’m playing a video game like league in which videos will start to have it as well.
picture uploaded was at its worst, typically wasn’t that bad.
https://linustechtips.com/topic/1349435-artifacting-issue/
Replace the video cable.
Dunno what you want to hear from us.
If the cable is okay I'm sorry to tell you that is GPU.
Also try to reset graphics card,check psu cables.
Run MSI Kombustor artifact scan.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1349435-artifacting-issue/#findComment-14819521
specs:
amd 5950x
32gb gskill
asus b550-f wifi
reseated cpu
tried old ram
temps seem stable
no power spikes
Try underclocking the core and memory of the GPU.
https://linustechtips.com/topic/1349435-artifacting-issue/#findComment-14819530
I plugged in a perfectly fine gpu and tested. Still happens. Read the post
https://linustechtips.com/topic/1349435-artifacting-issue/#findComment-14819738
