yada yada yada I upgraded the motherboard (msi b450  a pro to msi x570 gaming pro wifi)  and gpu without reinstalling windohs (yes i installed all the drivers needed) but ethernet connects for a split micro second on identifying then connected then it dips, comes back a few seconds later, wifi works great but ethernet not working is annoying id prefer not to reinstall windows because everything is working fine except the ethernet
https://linustechtips.com/topic/1349336-ethernet-problem/
Just now, gu3miles said:
What drivers did you install? It sounds like you didn't install the right chipset drivers. Did you find the exact chipset number and install those?
i double checked and went to msi website, when i rebooted windows after installing the hardware, it seemed to do everything except the gpu which is normal, but yes i double checked and they were both correctly installed
https://linustechtips.com/topic/1349336-ethernet-problem/#findComment-14818169
