Cpu cooler help
Go to solution Solved by mr cheese,
8 minutes ago, Rexy said:
So If I buy 120 mm nactua fan I can clipit on cooler
yes
why is it not fitting?
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1348918-cpu-cooler-help/#findComment-14815168
yes
https://linustechtips.com/topic/1348918-cpu-cooler-help/#findComment-14815196
doesnt' matter how you mount / clip it.
as long as the air is blowing to the heatsink, theres no wrong answer.
you can clip it, zip it, you can even tape it, if you don't mind the ugly look.
https://linustechtips.com/topic/1348918-cpu-cooler-help/#findComment-14816413
And if you really want to explore your ghettoness, you can use rubber bands (for a little while) and my personal favorite.. garbage bag twist ties. The cheap ones with the metal sticking out are the best.. just got to be careful 🙂
They are good for doing Spiderman rigging in your case. I have even used the twine you use to tie up meat for cooking.. of course zip ties would have been better if I had them at the time.. I have spliced fans in my case right now with duct taped wrapped around the bare ends because my kids did something with my electrical tape.
I am so ghetto I have a McDonalds straw that has a bolt with a rubber grommet on it holding up a triple slot GTX 580 in my kids Roblox box 😄
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1348918-cpu-cooler-help/#findComment-14816553
