Need an Android phone for my sister (US)
  • Factory unlocked. Needs to be used multiple sim cards in different countries
  • Gotta be $300 or lower, preferably closer to $200.
  • Dual-sim preferred, wide international band support essential
  • Needs to have long battery life, whether through a 5000+ mAh battery or clever software tricks
  • 5G please
  • Decent camera, though we both use GCam so it's forgiving
  • A good screen and speakers aren't essential but they're definitely nice to have
I was leaning towards a G9 Power, ticks every box besides 5G, but she wants to keep this phone for 5 years or so, figured it was important.
Looking forward to your recommendations!
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1348664-300-android-battery5g/
22 minutes ago, huilun02 said:
Please provide link(s) to the seller you intend to buy the phone from.
I don't see how a 720p screen and single bottom firing speaker can be considered 'good'
Like I said they're not really a priority. Any US seller that has factory unlocked phones - Amazon, Best Buy, wherever.
https://linustechtips.com/topic/1348664-300-android-battery5g/#findComment-14813479
10 hours ago, huilun02 said:
The phone he suggested is in that list...
A lot of them also don't work with a wide range of US bands.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1348664-300-android-battery5g/#findComment-14814381
The G9 power apparently works with T-mobile as my G7 power did, but honestly just considering a Pixel 4a 5G. It's $50 over budget but just seems like a good phone overall, and the small ~3800mAh battery apparently lasts all day thanks to the lower tier specs and OLED screen
https://linustechtips.com/topic/1348664-300-android-battery5g/#findComment-14814440
We're only a few months away from the 5A. Might be worth waiting.
https://linustechtips.com/topic/1348664-300-android-battery5g/#findComment-14814449
Ah good point, she does need something soon though, her phone is literally falling apart, and unfortunately leaks suggest an August launch. Damn it, we really like the idea of the Pixel 5a, because it'll probably keep the OLED screen and have 5G for $350.
https://linustechtips.com/topic/1348664-300-android-battery5g/#findComment-14814482
