Budget (including currency): Around 2300 CAD.
Country: Canada
Games, programs or workloads that it will be used for: Photoshop, Lightroom, Blender, Premiere Pro, After Effect, 3D Rendering
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Here's a parts list i've made so far, what do you think? https://ca.pcpartpicker.com/list/4RGYDc
https://linustechtips.com/topic/1348526-pc-build-thoughts/
Country: Canada
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Here's a parts list i've made so far, what do you think? https://ca.pcpartpicker.com/user/cejolly18/saved/RRwH23
it says that the page requested could not be found. try repasting the link.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
https://linustechtips.com/topic/1348526-pc-build-thoughts/#findComment-14812198
That should be it now, It was on private accidentally
get b550 instead of a520
and maybe get like a scythe fuma 2 cooler or an arctic esports duo.
otherwise, looks good!
Gaming PC:
https://linustechtips.com/topic/1348526-pc-build-thoughts/#findComment-14812982
