Recently I bought an EVGA 650W semi-modular BQ 80 Plus Bronze Power supply unit from a retailer in UK. I have encountered a problem which I am not sure what is caused by. As I connect a peripheral cable to it some defense triggers and it shuts off the PSU, so I wonder if it is caused by a conflict in the circuits between any of the peripheral/sata slots on the PSU or the cable is faulty or the power supply itself is not working properly. Can you advise please, if I am not doing something right or I should request a return.
https://linustechtips.com/topic/1347791-psu-issue-with-cables/
45 minutes ago, te4kotonik94 said:
shuts off the PSU
That sounds like over-volt protection is kicking in, what system are you trying to power with it? What are your components?
RYZEN 7 3700X / MSI X570S TOMAHAWK MAX WIFI / ZOTAC 3070 TWIN EDGE OC / CORSAIR VENGEANCE RGB PRO 32GB @ 3200 / SAMSUNG 980 PRO M.2 / WD BLACK SN850 M.2 / GIGABYTE P750GM 80+ GOLD / MSI MAG FORGE 100R / MSI MAG CORELIQUID 240R
https://linustechtips.com/topic/1347791-psu-issue-with-cables/#findComment-14806404
