As the title says, my s7 edge is boot looping. I took it to a t-mobile tech and they were unable to fix it. I've also tried factory wiping the phone and flashing it with new firmware using odin and neither has worked (Odin3 says it succeeded but the phone is no different after the whole process). After all of these options is it safe to say that the phone is done for? Or are there some other things I could try, thanks!
https://linustechtips.com/topic/1347481-s7-edge-bootloop/
Samsung android phone yes?  The problem with t-mobile stores is you may get someone who knows more about sales and the t-mobile software products than the particulars of that device.  It’s hardware is going to be relatively unique to that model.  Might need a really specific venue like a Samsung tech or something.  Looking up the phone it apparently was announced in 2016
https://m.gsmarena.com/samsung_galaxy_s7_edge-7945.php
so if it then came out in 2017 it would be a four year old design.  My memory is a lot of android stuff is only supported for 3 years or less so it might just be ewaste.
https://linustechtips.com/topic/1347481-s7-edge-bootloop/#findComment-14803698
After posting my original post I found a program called twrp. I don't know if you know anything about the software bit it seems like it could fix my issue if I could find the right version to flash to my phone.
https://linustechtips.com/topic/1347481-s7-edge-bootloop/#findComment-14803715
Thats also a flashing ROM, used to flash another ROM in. You could try load in something like LineageOS in it, but if even stock ROM specific to that T-Mobile S7 doesnt work, i doubt custom ROM could either.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1347481-s7-edge-bootloop/#findComment-14803764
TWRP may be able to help you out, but only just. For example if this is hardware related and not software, then TWRP can’t help. It may be worth flashing a different android OS to your phone to see if that works, but other than that I’m not quite sure what’s going on
https://linustechtips.com/topic/1347481-s7-edge-bootloop/#findComment-14803828
Ah crap I just now realized I low key copied your comment, when you agree’d to my post all I had to do was look up and saw yours lol. I really am sorry about that, I need to start using my computer on the forums besides my stupid SE lol.
https://linustechtips.com/topic/1347481-s7-edge-bootloop/#findComment-14804950
