hi i was looking at closed loop water coolers and i noticed that the h100i is multi socket i was wondering what that means. because i was also looking at the glacier 240l from cooler master and that is expandable. is multi socket and expandable mean the same thing
No. I can't explain now, my phone is about to die.
then why leave a reply lol.
no, multi-socket means it supports multiple sockets (ex. LGA1150 & FM2+ & AM3+)
expandable means you can add things to it (like a res, another CPU block, more radiators, a GPU block)
^ was about to say the same
Just to say that they are not the same
thanks for the help. also should i buy the glacier 240l or the h100i
Do you actually plan to expand it?
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
well idk yet my motherboard has the compatibility and i was considering a custom loop in the future
I'd go for the H100i now and then if you want to do a full loop, get radiators, tubes etc. separate rather than adding to an AIO.
