5600x wont post
TLDR/ANSWER;
Bad motherboard now and will probably only ever accept the cpu in it now / RMA for new mobo
Seems like from a technician I spoke to because I used the 3200g in the motherboard it may have corrupted some form of the BIOS or way it reads the chip. The motherboard isnt intended to have a igpu in it at all and running a cpu with the igpu even though i never used it can have some problems. I have a warranty on the product but im instead going to remove the GPU build a new system with my old ram gpu. Eat the 200 for a new motherboard and then use the old mobo and cpu as a home PC for my gram as she will never need a independent GPU and after running some tests the computer boots and runs without the GPU at all which isnt supposed to be a thing. I thank anyone who took the time to check this post and anyone having the same issue I hope this helps.
