My first ever PC build
39 minutes ago, Albert F said:
is that cooler pointing... downwards? also what the heck is that extension? no offense I'm getting triggered the more I look.
p.s post your spec, doesn't matter if they are low end
Here are it's specs:-
Pentium 4 PresHot 2.4 GHz  (socket 478)
2 GB DDR2 800mhz ram
160 GB WD harddrive
Cheap PSU and case picked up from boot fair.
Also what's the problem with the cooler pointing backwards?
https://linustechtips.com/topic/1346492-my-first-ever-pc-build/#findComment-14796660
160 GB WD harddrive
If the cooler is pointing downwards it is not pushing the heat outside the case and it is keeping it inside basically making your PC an oven box
https://linustechtips.com/topic/1346492-my-first-ever-pc-build/#findComment-14796802
The cpu cooler is an intake and I have a  Exhaust fan on the back side of the case anyway so that shouldn't be a problem.
https://linustechtips.com/topic/1346492-my-first-ever-pc-build/#findComment-14796829
  • 2 weeks later...
