4 minutes ago, Birdlaws said:
Dumb question I purchased this cpu cooler and want to make sure this is normal? In the corner. Thanks !
Was it perfectly sealed when you got it?
Try wiping that area with a barely damp cloth...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1346417-cpu-cooler-help/#findComment-14796143
