Hello there!
I've recently wanted to sell my two 970's and buy a single RTX 3060 once they are back in stock (If ever...)
I've been nervous selling both GPU's because I was worried I'd sit for months with nothing in my PC, so I figured I'd only sell one.
So I unplugged one of the two cards and set it aside, I booted everything up with the other one in the PC.
I went to go load up Nvidia control pannel but it had dissapeared, and GeForce experience would not let me go to the games or profile tabs.
I loaded up GTA V and noticed it thought I still had 2 GPU's installed (showed 8Gb of VRAM when there is only 4Gb per card)
I was wondering if this was a driver issue and how to fix it.
I reinstalled the other GPU and all is back to normal.
Thank you in advance for any advice and whatnot.
https://linustechtips.com/topic/1346347-problems-going-from-sli-to-single-gpu/
Run DDU and install the gpu drivers again
