Need descision help
Solved by Freakwise,
20 minutes ago, Lejee said:I was more wondering if someone have knowledge about the ventilation and the in system performance (SpecSheet alone won‘t tell everything)
If thermal is one of your concern both of those will have enough power to cool down a 3060 and 5800h
G15 has a lot of complex heat pipe while legion have a "butt" to support it's overalls bigger heatsink to have better thermal performance
(G15)
(legion)
tho Zephyrus is still overall better
Tho it's has one channel of the ram soldered leaving you with only one stick of upgradable ram
