Typically yes, if it's coming off of a motherboard header then yes, most definitely.
However, if it's coming off of a molex powered fan controller, then it might not decrease as much, as it'll draw more current through the controller (Assuming the controller is rated for enough power)
| CPU: Intel i5 3570K @ 4.4GHz 1.26v | GPU: AMD R9 290X @ 1090MHz |
| RAM: 2x4GB Samsung Green @ 2133MHz OC |
| PSU: Corsair RM850 | Case: Fractal Design Define R4 |
https://linustechtips.com/topic/13462-help-with-fan-preformance/#findComment-145175
If i get a 4 to 1 fan header will it decrease the preformance of the fans?
You should check the maximum power that your fan header can provide and your fans' power before connecting them to make sure that you don't overload the header and/or break the fans.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/13462-help-with-fan-preformance/#findComment-145687
