Help me! please.
By
Ischyros
in Troubleshooting
in Troubleshooting
Solved by NeoFriction,
In Valorant,is your v sync set to double buffered?Most people say that it is the culprit.
There is no need right now to reformat.First you can try everything you can.When you give up,you can reformat.
Try changing your power options to High Performance.
Also,if you have a laptop turn off battery saver.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
