Budget (including currency): ~2500 AUD
Country: Australia
Games, programs or workloads that it will be used for:
RTX minecraft
Video Editing
Streaming MC
3D model rendering in blender
Running 2-3 screen recordings of 2-3 Minecraft game sessions at once(not using RTX)
Running complex math formulas in MC
large storage
I have been looking for a while and come to realise theres a lot I don't know.
Video rendering and Minecraft Java both work on the CPU. RTX is graphics card
I'm changing from a macbook (where i have written mods and code for minecraft for the new PC build to run)
I have been told to look at https://www.scorptec.com.au/product/ready-to-run-pcs/gaming-pc/88494-ss-sentry3060 with upgraded ram, this could be a start but I cant tell if its upgradeable in the future
I have been told to look at https://www.pccasegear.com/products/54176/pccg-hellfire-6700-xt-gaming-system but another site said this isn't going to be a good deal
there was also this suggestion https://techfast.com.au/products/AMD-Ryzen-5-5600X-RTX-3070-8GB-Gaming-PC-May?utm_source=ozbargain&utm_medium=deal&utm_campaign=5600X-3070-MAY
I am looking for something that doesn't break the bank (i can go over 2500) and it doesn't need to be a pre-build but thats the only advice I have been given
The essentials are running Minecraft at a high-end, this means running shaders (ill be testing shaders i work on), while recording and streaming.
I don't know much about refresh rate etc as the macbook was a macbook and I didn't need to think about anything like that since there was no point because its a macbook and nothing can change in it
https://linustechtips.com/topic/1345945-help-with-build/
Ahh a fellow aussie 😛 Well due to the current market, I would try put 1.5k to the PC and 1k to the GPU so u might be lucky if you can get an RTX 3060 ti or RTX 2070 Super off Facebook Marketplace and maybe a 3700x/5600x CPU
Discord : https://discord.gg/AuFFAA5FAp
PC Spexifimacations :
- AMD Ryzen 7 5800x 8c/16t Zen3 Desktop Processor
- GeForce RTX 3080 EAGLE OC 10G (rev. 2.0)
- G.SKill Ripjaws 32GB (4x8) 3200MHz CL16
- Gigabyte X470 Aorus Gaming 7 Wifi (Super Sexy Indeed)
- 1TB WD Blue NVMe M.2 SSD + 4TB 2.5" 7200RPM HDD
- Corsair RM750x 750 Watt 80 PLUS Gold Certified Fully Modular PSU
- Coolermaster TD500 Mesh-G (with all fans)
https://linustechtips.com/topic/1345945-help-with-build/#findComment-14792620
Heres a lil list I compiled from Centrecom for a nice build (unfortunatley they dont have ability to share a link so you can just look at the screenshot). Build consists of a Ryzen 7 5800x + RTX 3060 if you can mange to find em. I wasn't sure what your other build preferences where so I went RGB all they way with no Wifi+BT, Anyways. I did not pick a CPU cooler but the 5800x does NOT come with one so u will need to pick one but typically for $30 you can get an AMD Wraith Prism off facebook marketplace. If you want you could drop the CPU down to a 5600x or 3700x if you wanna free up some cash for other stuff.
https://linustechtips.com/topic/1345945-help-with-build/#findComment-14792658
R5 5600x CPU
RTX 3060 GPU
NZXT Kraken 240mm AIO
Corsair Vengeance LPX 2x8GB 3600MHz RAM
Asus TUF GAMING B550-PLUS (WI-FI) ATX AM4 Motherboard
Samsung 970 EVO 500GB SSD
Seagate Barracuda 2TB HDD
EVGA GD 600W 80+ Gold PSU
Corsair iCUE 220T RGB Airflow Case
Microsoft Windows 10 Home OEM 64-bit
https://au.pcpartpicker.com/list/RhtxJf
https://linustechtips.com/topic/1345945-help-with-build/#findComment-14792995
That case has little airfow, that PSU sucks, and that RAM is way too overpriced.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1345945-help-with-build/#findComment-14793092
58 minutes ago, SomeRandomNerd said:
R5 5600x CPU
RTX 3060 GPU
Case is meh value, AIO is terrivle value and not needed, SSD is also terrible value, and that PSU is quite mediocre.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1345945-help-with-build/#findComment-14793097
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($419.00 @ Amazon Australia)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($152.00 @ Amazon Australia)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($119.00 @ Amazon Australia)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive  ($73.00 @ Amazon Australia)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ BPC Technology)
Video Card: Asus GeForce RTX 2060 6 GB DUAL EVO Advanced Video Card  ($597.00 @ I-Tech)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($79.00 @ PCCaseGear)
Power Supply: Enermax Revolution D.F. 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.00 @ Mwave Australia)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  ($15.00 @ Mwave Australia)
Total: $1631.00
Generated by PCPartPicker 2021-06-10 00:23 AEST+1000
geometry is hard
b550 > x570
https://linustechtips.com/topic/1345945-help-with-build/#findComment-14793112
