First build part lineup
Solved by Anton Foch,
Great build, i think 32g of ram is a bit overkill, would go for 16g.
For the cpu, since you have a pretty good budget you should go for Ryzen 5 5600x.
Mother board is perfect !
you should upgrade your storage, go for 1tb of ssd.
the pwr supply is good, i would suggest Corsair RMx 2018/2015 but yours is good too.
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory11
play_circle_filled
Latest From ShortCircuit:
