5 minutes ago, DxRalph said:
Hi guys,
So ive been using my 3080 for a while now and games arent really performing how i expect them to. I have noticed that at this point my 2700x creates a small bottleneck and i was thinking of getting a 5600x. Is this a big upgrade? Thanks!
according to
, possibly up to 2-30fps difference if 1080p or 1440. 4k, will be no difference
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14786328
14 minutes ago, DxRalph said:
I mostly play at 1440p and i notice that im not getting quite to 144 fps in a lot of titles where i think i should on the 3080
Hmmm... How much is it compared to your expectations and other people results?
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14786383
17 minutes ago, DxRalph said:
in most games im not getting full gpu usage as my cpu usage spikes. games such as apex i hardly ever have a stable 144fps
if you also do things that require a lot of core like in your current 2700x
you'd probably better using a 5800x but if majority use case of your pc 5600x theoretically it should be fine i guess
also out of curiosity what is your overall system spec
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14786961
Just chasing an arbitrary number.
If you where doing competitive 1080P, maybe you want high fps then and a cpu upgrade would improve this situation better.
My 2700X drives an RTX 2060 at 4k. We just don't watch the counter and it's fine. But pretty much 60fps gaming. I don't expect more from this. I would need a 3080 then... which is better suited for 4k.
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14786971
I have a 2700x running at 4.2ghz, a 3080 Surpim x, 3000mhz teamgroup ram and an rm750x
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14788858
is the cpu usage really high? like 80+
changing to 5600x or 5800x could help but i suggest you to watch some review or comparison
but a 3080 for 1080p is kinda overkill and stepping it up to 1440p or even 4k will bring most of that gpu power
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14788876
when under load, certain of the cpu's do hit over 80, sometimes over 90. I do game at 1440p so the cpu will still have an impact i presume.
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14788956
You'll never be completely free of some kind of bottleneck - ultimately it's the question of if you are satisfied with your performance or if you feel the drops are enough to disrupt your experience.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1345102-2700x-bottleneck/#findComment-14788959
