So I am working on Fabricating my own case and am trying to figure out my NZXT 120mm AIO layout. I am building the entire case to be laying horizontal and i am trying to figure out if its okay to have the AIO cooler sitting horizontal next to the MOBO pulling air up into the case as well. I assumed if I have the CPU block and the Radiator even with each other i shouldn't have a problem with air trapped in an unwanted spot. If anyone has some input if this is a good or bad idea please let me know before i start cutting holes!!
Thanks
https://linustechtips.com/topic/1344591-aio-cooler-sitting-horizontal/
Thanki
It's should be fine i guess
If you planning to do it all horizontal
Like some thermaltake open air case make sure that the pump is the not the most high places than any other part of the aio, it could be the tube
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Thank you very much for your input, i thought it would probably be fine, but needed another opinion on it,.
