Budget (including currency): $1200 USD
Country: USA
Games, programs or workloads that it will be used for: RTS(CK3) to FPS(Call of Duty: Warzone)
Other details
https://pcpartpicker.com/user/TheDoubleX/saved/#view=wcCPFT
I am doing just the PC budget before peripherals and monitors, though I plan on using one monitor and then maybe two.
I want to know if anything seems wrong or if there are things I could do better.
https://linustechtips.com/topic/1344454-my-first-build/
Country: USA
Other details
Only thing I can think of off hand looking at it is that gpu seems pretty cheap.  MsRP even. GPUs are one of those things that have been hard to find like lumber and bullets and some other stuff. there are people saying it will stay that way till the end of the year too.  I’m not sure they’re right, but it is being said.
 My personal running plan is if I’ve got to build something quick, to find out what gpu I can get and then build a machine around that.  Secure the Video card first, then worry about the rest of it.  The 10700k has an iGPU in it though so even if you can’t get ahold of a video card the thing will still run.  You could browse the internet and watch videos and stuff.
https://linustechtips.com/topic/1344454-my-first-build/#findComment-14781577
Yeah the gpu is sold for 400 at some places but only every 2 weeks or so, I just hope to get it whenever that happens.
https://linustechtips.com/topic/1344454-my-first-build/#findComment-14781594
I would say step one is getting hold of a card and then worry about the rest of it after that is secured.  This will stop being the way things need to be done, hopefully, but for right now it’s the way it seems to be.  Might actually be a lot of cpu for that video card.  Depends on use case though.
https://linustechtips.com/topic/1344454-my-first-build/#findComment-14781613
PCPartPicker Part List
CPU: Intel Core i7-10700K 3.8 GHz 8-Core Processor  ($314.99 @ Newegg) don't expect to overclock with a B460 board though.
CPU Cooler: Gelid Solutions Phantom CPU Cooler  ($36.99 @ Amazon)
Motherboard: MSI B460M PRO-VDH WIFI Micro ATX LGA1200 Motherboard  ($109.99 @ Amazon) much better board for the i7.
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  ($76.99 @ Newegg)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive  ($108.47 @ Amazon)
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Corsair CX (2017) 750 W 80+ Bronze Certified ATX Power Supply  ($72.98 @ Amazon)
Total: $790.40
Generated by PCPartPicker 2021-06-04 07:52 EDT-0400
https://linustechtips.com/topic/1344454-my-first-build/#findComment-14782104
