Hey everyone,
I have a issue with my headphones (Drop Panda). My pc recognizes the headphones as 2 diffrent devices/outputs. one when plugged into the pc and one when using bluetooth.
Is there any workaround so that if I'm plugged into my pc via usb, the pc recognizes it as the same audio device as when im connected via bluetooth or the other way around?
or a program that combines the  2 outputs into 1?
I cant use the stereomix, because only 1 of the 2 outputs is connected at all time.
the headphones dont support audio playback via bluetooth while charging.
im in desperate need for a solution. i hope someone can help me out
https://linustechtips.com/topic/1343797-combining-2-audio-outputs/
...but this is normal behavior. Just disconnect the bluetooth on the settings when youre not using it or select from sound settings.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
-> Moved to Audio
You can't use both connection methods. It prioritizes USB, and ideally should switch automatically to BT when USB is disconnected. Windows BT handling is the main issue I can think of. But you could use also 3rd party software solutions where you can switch audio devices with hotkeys.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
