These are my specs I upgraded from a Asus Dual 1070 to an MSI GamingX GeForce RTX2070 Super and I've been experiencing mixed FPS lately in games I play on 1080p I simply want clean 60FPS on highest settings I believe so should be well equiped for it but I'm having unstable FPS dropping to 45 but never a solid 60. Is anyone else experiencing this nightmare? If there's anyone that might recommend something I'm willing to try. Already use DDU and performed a clean install and also rolled back 1 update. O feel like 2070s was such a bang for the $ that they're purposely messing with the drivers. I've seen a lot of mixed experience and inconsistency from the gaming community.
https://linustechtips.com/topic/1343488-cod-warzone-optimization-issues/
I assume you turned off ray tracing?
This game is becoming known for it's degraded performance. If you look up this game + performance issues, you will see why.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
