what games are you playing?
For non-demanding ones like League of legends, this is normal.
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1342855-low-gpu-and-cpu-usage/#findComment-14768919
I play valorant about 20 to 70 fps depending on gameplay but I just took apart my pc and put it back together and me turning my power on works my 1650 super shows it's light and my tuf b450 motherboard lights are on but when I hit my power switch it doesn't turn on so rn that's my biggest problem and hopefully I can fix it since it's my only form of entertainment rn also I fixed a major issue with my cpu
https://linustechtips.com/topic/1342855-low-gpu-and-cpu-usage/#findComment-14769104
