Budget (including currency): $3000 CAD, can go up to $4000 but would prefer to keep it closer to the $3000 limit.
Country: Canada (Alberta)
Games, programs or workloads that it will be used for: AutoCAD, Inventor, misc game examples being Satisfactory, 7DtD, DSP, Valheim.
Parts I will be moving forward for now are my GPU (1080ti), power supply EVGA 750 watt, 4 DDR4 8gig 3200 MHz sticks. Everything else needs replacing including case. Peripherals are not needed.
I don't really care about RGB or looks just functionality, however I would enjoy a USB-C front header and would prefer to avoid AIO's.
EDIT: Also wonder if its worth it to wait and see what these new Intel CPUS's are like with the DDR5 support. If possible I would like this new build to hold me 4 years similar to my last build so future proofing would be nice.
https://linustechtips.com/topic/1342678-work-and-gaming-pc/
What are your current specs? Just as a frame of reference (mainly the cpu).
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767717
CPU: Intel i7-7700K CPU
Motherboard: MSI Gaming M7 ( Upgrading due to progressive failure of this part.)
GPU: 1080ti (Plan on replacing this down the line but due to current events it will work for now)
RAM: Corsair 8gig 3200MHz x4 (I think its the Vengeance series. Black sticks either way)
Boot Drive: Intel 760P Series SSD
Power Supply: EVGA 750watt
Case: Corsair ? (Similar looking to 5000D)
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767724
Is there a current performance issue with it? Part from well dying board. If not a simple board swap will do the trick and allow you to go for a true next gen upgrade.
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767744
Currently the issue is just the dying board. Would it be worth it to either wait for the intel release later this year or the next AMD zen's? Always warry of constantly waiting for that next big tech release but if it's worth it then I could do that.
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767757
It does make sense to wait if the current cpu is good enough. More so to prevent being on now end of life platforms. Since you can basically take everything you want to take with you to am5 already.
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767775
For 2400 USD you can basicly got a Ryzen 9 5950x with a sick X570 Motherboard in it. And reusing your PSU and Ram maybe not a bad idea either
Here's my build for 2400 w/o ram or psu: https://pcpartpicker.com/list/f7M4fP (The Case Support for Type C Plug, yeah it is with RGB goodness)
Hello there... I'm both speedrunner and tech nerd. But not professional...
steam pcpartpicker.com speedrun.com
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767779
But if you want you can wait another few year just to get the better timing, Because building a PC Nowadays can be rough, Especially with these semiconductor Shortage and mining boom
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767784
Thank you for the help today! Will replace the motherboard and hold on for now.
1 minute ago, XnonXte said:
But if you want you can wait another few year just to get the better timing, Because building a PC Nowadays can be rough, Especially with these semiconductor Shortage.
Think that's what I'm going to do for now. Thank you for your previous suggestion though!
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767790
No need to go expensive again tho. Plenty of good used boards for under 100 that are really good.
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767800
https://ca.pcpartpicker.com/list/8DFb9N  both case and motherboard support usb type c and for the case go with the mesh one same price for some reason pcpartpicker dosent show it and for the ram and storage you can use your old ones as well it will be 1074 cad
https://linustechtips.com/topic/1342678-work-and-gaming-pc/#findComment-14767967
