my temp is so high when loading up games or installing something it's reaching 70c to 80c
my idle temp is 45c to 54c
my cinebench r23 temp is 67c
my temp while gaming 60 to 75 it depends in game
my main problem is, is this normal when i'm opening tarkov or loading to a map my cpu temp will spike up to 75 to 80c
CPU : Ryzen 9 5900x (stock)
Cooler : NZXT Kraken Z73
Mobo : Asus ROG Strix X570 E Gaming
https://linustechtips.com/topic/1342164-5900x-temps/
those temps are actually normally.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1342164-5900x-temps/#findComment-14763798
8 minutes ago, EmperorShionplays said:
this is my first amd build. this only happanes when im opening game or installing something the temps would spike so high
its because the BIOS is tuned to think it needs more than it does and once it realized how much juice it actually needs, its settles back down.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1342164-5900x-temps/#findComment-14763832
