Using Multiple External USB HDD Drives At Full Speed Requirements?
Solved by nick name,
The Startech USB PCIe card with UASP came in and seems to allow for much better simultaneous HDD write speeds. Oddly it doesn't seem to perform as well as the USB hub, but it's definitely much better for moving files between drives than the onboard USB ports. I also replaced the HDD sleds that had deteriorated mounting grommets so I have two less external HDDs to hook up via USB enclosures.
I am still curious if a multichannel USB PCIe card would have been the ultimate solution though.
