Im not a newbie to pc building but i havnt ever gone custom water cooling before but its my end goal for my pc. i have an rtx 3060 and i know it doesnt need to be water cooled but i wanan do it for the looks (IF I CAN) now i dont believe you can get waterblocks for a 3060 can you? if you can please correct me. but if not, what 3000 card do you recomend me to get for water cooling, i was a thinking a 3080
https://linustechtips.com/topic/1341623-water-cooling/
You have a 3060 that's perfectly fine, but you want to buy a 3080 just to water cool for aesthetics?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1341623-water-cooling/#findComment-14759700
not that it's necessarily a matter of options, but if you're new to watercooling starting with a waterblocked from factory card could be an easier starting point. Honestly, if you're buying blocks from EK on top of buying the necessary card you could end up spending as much or more while still having to install the block yourself because of shipping and tarrifs. The other option is to waterblock a less expensive card for your first time like I did. I personally water blocked a 5700xt reference card when they launched. I guess if you're in the UK my tariff experience probably won't apply, but worth mentioning for the other people considering this.
https://linustechtips.com/topic/1341623-water-cooling/#findComment-14759749
yeah thats fairly true, i want to do it my self as im into the learning experiance of it, ive taken apart many gpus for various different reasons but never waterblocked one.
https://linustechtips.com/topic/1341623-water-cooling/#findComment-14759755
