Hi everyone, thanks for reading my thread.
I am relatively new to twitch, I’ve been streaming on and off for a few months and want to take my stream to a decent level and would really appreciate any help.
My last stream had some lagging. It I’ve fixed it now.
PC:
5600x
6700 xt
16gb ram
1tb ssd
obs settings:
H265/GPU
6000 bitrate
1280x720
twitch: quality preset
60 fps
twitch:
overlay: stream elements
alerts: nerd or die pack
gear:
Sony camcorder with cheap capture card for webcam.
razer Seiren elite mic
if anyone has any suggestions how I can make my stream better any help would be highly appreciated.
Thanks!
https://linustechtips.com/topic/1341082-twitch-stream-help/
  • 4 weeks later...
Hi I am having some issues with my twitch streaming as well and I cant trace down what it is. Basically I am having this issue on 2 systems. Both use OBS Studios for streaming. Both use the NVENC on the NVIDIA GPU's for the encoding. I am getting an encoding overload error issue along with dropping FPS on the stream. Network stays green, but the encoding issue happens as of late. Its happening on both systems
Desktop:
Ryzen 7 3700X/ 32GB DDR4 3600MHz/ 1TB Samsung 970 Pro NVME drive/ GTX 1660 (yes I know its a mismatch but cant find a better one) with Windows 10
Laptop:
Asus Tuf Dash f15: i7-11370H/ 16GB RAM/ RTX 3060
In order to get them to not show the encoding issue, I have to do 720p 30 fps. If I do 1080p 60, even though my bandwidth supports it (1gb up/down), I get the encoding Overload. and both systems have 1080p 144hz monitors. Any help someone can provide I would greatly appreciate it. Ive tried everything I could think of and nothing I try is working
https://linustechtips.com/topic/1341082-twitch-stream-help/#findComment-14819107
