This depends on the program, programs like editors are demanding and a usb wouldn't be ideal but may be possible. So yea it is possible to run it off of your usb (key word POSSIBLE)  :D
I fix computers and computer accessories... sometimes... when I want to...
For photoshop it needs to be a portable version of the software.
Its possible depending on the program, programs which require registry information and whatnot during installation may not work when you copy it to a flash drive.
Running programs off a flash drive will be slower too. Diagnostic software is usually able to be ran off a flash drive though not advisable.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
PortableApps.com has a lot of different programs.
They have GIMP which is similar to photoshop. No Steam though.
CPU: AMD RYZEN 7 3700x CPU Cooler: AMD Wraith Prism Motherboard: MSI MPG X570 Gaming Plus Memory: Corsair Vengeance RGB Pro 16GB (2x8GB) SSD: Samsung 970 Plus 250GB NVME, WD Blue 2TB m.2, Crucial M500 240GB GPU: EVGA GTX 1080 FTW PSU: Seasonic G-Series 550W CASE: Corsair 220T RGB
If the software doesn't write lots of information to the drive, then you'll be okay. If it writes lots of information, you'll need to be careful that it won't wear out the drive (which happens much faster on a USB stick than an SSD)
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
