42 minutes ago, Joshanater said:
Honestly unessesary to monitor coolant temp. You should just make it relative to CPU and GPU temperature.
Its the same price of Corsair Commander Pro, so that can be good shot if this is out of stock.
But beyond that, its all good.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
18 hours ago, Joshanater said:
Probably overkill, but looks solid. Nobody can tell you whetcher you have enough fittings or not. Depends on your very specific layout.
You could save quite a lot by going for Arctic P12 fans. I'd suggest a Aquaero 6 LT instead of the OCTO fan controller - gives you a lot mor control.
Ramping your radiator fans up according to CPU/GPU temp spikes makes no actual sense - they cannot directly cool down those components. The heat gradient between coolant and the water blocks is the most important factor. If that goes up your fans need to go up.
Use the quote function when answering! Mark people directly if you want an answer from them!
