I am looking to buy a microphone boom arm for my razer Seiren elite, I have a cheap newer one I got for $15 but my mic is to heavy and Te arm falls down. I was going to buy a psa1 or blue compass but I found they are very long and tall. The stand is only mounted about half a metre away from the mic so it doesnt need to be any bigger then 30cm by 30cm. I can find anything like this that is short enough. If anyone has any recommendations please let me know, Also i can mount it on my desk or upside down on a wall mounted shelf.
thanks in advance.
https://linustechtips.com/topic/1340716-best-microphone-stand/
thanks in advance.
Is the Neweer NW-35 available for you? You will need a 5/8 to 3/8 screw adapter for that mic if you haven't had one already.
big man big w!
https://linustechtips.com/topic/1340716-best-microphone-stand/#findComment-14754986
tha that’s what I currently have but it can’t hold the weight of my mic and I was looking for something more premium. Thanks though
https://linustechtips.com/topic/1340716-best-microphone-stand/#findComment-14755636
