Hello, here is the thing i got new keyboard and i noticed that there is very low vibration going on when backlights are ON the higher the lights the higher vibration in headset, altho if i turn off vibrations on headset i dont hear it. Also the thing i noticed now is when i move mouse BUT only when selecting text (for now) it emits same sound slightly lower its rly rly quite i bet that some people would not even notice how low it is. i checked some useage in task manager i saw that the moment i turn lights on disk 1 get some usage. When i unplug KB mouse sound still exists, so i dont think it KB related any tips? Thanks!
PS: Tried front and rear plug for headset and keyboard same thing... I dont have other headset with vibrations to test, i also use HDMI adopter if its of any use. I cant be certain since im not a bat but i believe that there is very low vibration even when nothing is going on from headset, and other people hear my background from mic so i use ptt, if any of this is of any use... I just noticed that the sound is comeing only from left *ear* and right on is silent 100%
Edited by Howl.....
aditional info
https://linustechtips.com/topic/1340654-leds-emit-sound/
Keyboard is Shiva K512, headset is some old Genius i had as backup in case some break, and mice is G902 pretty much new. As for power supply it should be replaced since i managed to break that little ring that was holding the fan so my PC i horizontaly placed so fan does not move while rotateing, its some stock ive got with the case maybe 5 years old.
Motherboard: H81M-R
CPU: i5-4460
GPU: 1050 ti
Ok now this is weird, if i change color form Blue to Red i cant hear it....
Hear on: Blue, White , Pink, Yellow
Dont hear on: Red, Dark blue, Green
https://linustechtips.com/topic/1340654-leds-emit-sound/#findComment-14752940
